VIKTOR cli - Could not clear entities and entity types: status code 504
VIKTOR cli: v0.9.3
The VIKTOR-cli was no longer able to clear entities and returned the following error message:
Could not clear entities and entity types: status code 504.
Rebooting my laptop solved the issue
The cli should be able to clear entities and if not, return a more explicit explanation of the failure
I doubt that this had to do with your laptop. Exit code 504 is a standardized HTTP exit code that signals a gateway timeout (504 Gateway Timeout - HTTP | MDN).
Last Thursday the platform experienced some issues which I think might have caused your error.
I have received the same error (but with different status code) multiple times as well:
Exiting because of an error: Could not clear entities and entity types, status code 502
It only happens when I have a lot of entities in my database (500+).
Running the same command a few times eventually clears the database and returns a:
Successfully cleared entities and entity types
This issue has been resolved with CLI version v0.19.1, where we have introduced retries. See cli v0.19.1 release
