Hi, I am working on an app where I need user to upload few files (.png, .txt, and .xlsx). Excel file will be having multiple sheets. I will read these sheets as different dataframes . How can I achieve the upload part and then reading sheets individually as dataframe?
Hi Abhi,
Thank you for your question. Here to answer your different questions:
- How can I achieve the upload part? This can be achieved by means of using a
FileField. More on this can be found here: User input, fields and buttons - Upload files | VIKTOR Documentation - How can I read sheet individually as dataframe? There are different ways of achieving this with different python packages. Here is a link with a solution: python - Using Pandas to pd.read_excel() for multiple worksheets of the same workbook - Stack Overflow
Here is also a small snippet that goes through these steps:
import pandas as pd
def excel_to_dataframe(params) -> pd.DataFrame:
if params.upload_file:
excel_file: File = params.upload_file.file
excel_data = pd.ExcelFile(BytesIO(excel_file.getvalue_binary())
df = pd.read_excel(excel_data, 'Sheet1')
return df
The conversion from a File object to an ExcelFile was partially solved by using this link as reference:
I hope this helps.
