I often struggle with converting a matplotlib plot from a script to a functioning view in VIKTOR. How i normally do this:
- copy paste the example from the docs
- modify for my needs
Allthough this doesn’t take very much time, it feels unnecessarily difficult. What if I would have a dedicated MatplotlibView?
Inspired by the TableView, I created the following code that enables this:
from io import StringIO
import numpy as np
import matplotlib.pyplot as plt
from viktor.parametrization import ViktorParametrization
from viktor.parametrization import NumberField
from viktor.views import ImageResult, ImageView
class MatplotlibView(ImageView):
pass
class MatplotlibResult(ImageResult):
def __init__(self, plt_):
fig = plt_.gcf()
svg_data = StringIO()
fig.savefig(svg_data, format='svg')
super().__init__(svg_data)
constant_a = NumberField('A',default=1)
constant_b = NumberField('B', default=1)
constant_c = NumberField('C', default=1)
label = 'My Entity Type'
@MatplotlibView("Plot", duration_guess=1)
def createPlot(self, params, **kwargs):
# standard matplotlib code
x = np.arange(-10, 10, 1)
y = params.constant_a * x ** 2 + params.constant_b * x + params.constant_c
plt.plot(x, y)
plt.show() # this is not necessary here but often part of examples
return MatplotlibResult(plt)
