Hii all,
I have a question regarding the OptionField in a table. Is it possible to have row dependend option fields? For example a table with two columns, in which the first column is a column of names and the second columns should show options of properties of that name. As the names in column 1 are different, the possible should also differ and be row dependend.
Now you can use a call back function that returns a list of options, but can you have different lists per row?
Hope you can help me
Auke
