Filefields (and files) are not copied when copying an instance
SDK: v13.2.1
Platform: v22.06.3
not sure if it is intentional:
When copying an instance (with filefields) the files are not copied.
I would expect every parameter is copied.
Hi Wichard, thanks for reporting.
We are aware of the issue but do not yet have a solution. I will add your report to the internal issue.
Mentioned again in File field error when copying entity
Any update? It seems many users do copy an entity to calculate a variant. However they all complain about the fileField not working after copying it.
Here the same: A lot of complaints on that side. It seems that also File-Type Entities are not working.
I Would really appreciate an update on the progress.
Hi guys, apologies that this is taking so long. We appreciate you getting back to us and currently aim to work on a fix in March.
This has been fixed in the latest platform version (v24.04.3).
This update does not allow for files in storage to be copied, right?
Requested by @wouterhouzr
With the latest platform release v25.01.0 the data in Storage is also copied when copying entities
