Adding workspace_id to set_params
Since the new SDK update 14.9.0 API method set_params requires workspace ID:
  File "controller", in import_entity_and_children
    current_entity.set_params(params=last_saved_params)
  File "viktor\api_v1.pyx", line 589, in viktor.api_v1.Entity.set_params
  File "viktor\api_v1.pyx", line 1294, in viktor.api_v1._API.set_entity_params
ValueError: `workspace_id` is required if API is initiated outside of a VIKTOR app.
The problem is that workspace_id cannot be passed to set_params, however it is needed in this method as it uses set_entity_params, which does need workspace_id.
How can this be fixed?
Hi Peter,
This might be a bug on our end, depending on how you’ve set it up (it should autoselect the correct workspace id if run from within a app/workspace). Could you provide a bit more context on how you are using the API?
For example, are you using it within an app (seems likely, since your snippet mentions a controller)? e.g.
api = API()
current_entity = api.get_entity(entity_id)
current_entity.set_params(params)
or are you trying to do this from an external script?
api = API(token=x, environment=y)
Also, could you tell me which Connector Version you are running? You can spot this when you run your app:
2024-05-03 10:52:20.312 INFO    :  __      __ __  __  __
2024-05-03 10:52:20.312 INFO    :  \ \    / / | | | |/ /
2024-05-03 10:52:20.312 INFO    :   \ \  / /  | | | ' /
2024-05-03 10:52:20.312 INFO    :    \ \/ /   | | |  <
2024-05-03 10:52:20.312 INFO    :     \  /    | | | . \
2024-05-03 10:52:20.312 INFO    :      \/     |_| |_|\_\
2024-05-03 10:52:20.312 INFO    :   _______   ____    _____
2024-05-03 10:52:20.312 INFO    :  |__   __| / __ \  |  __ \
2024-05-03 10:52:20.312 INFO    :     | |   | |  | | | |__) |
2024-05-03 10:52:20.312 INFO    :     | |   | |  | | |  _  /
2024-05-03 10:52:20.312 INFO    :     | |   | |__| | | | \ \
2024-05-03 10:52:20.312 INFO    :     |_|    \____/  |_|  \_\
2024-05-03 10:52:20.313 INFO    : VIKTOR connector v5.24.2
 __________________________________________________^^^^^^^
Hi Kevin,
I was using viktor connector v5.22.2 in development. As far as I know I am not using it outside of an app, however I am trying to import params and pass them to a child entity of the entity that throws the error. Before we just had:
        entity_id = kwargs.get("entity_id")
        current_entity = API().get_entity(entity_id)
Which used to work fine. Since the update it says it needs a workspace_id.
Hi Peter,
I think that the problem lies in the older connector. The autoselection of the workspace_id was introduced in v5.24.0 (released on 14/03/2024). Could you reinstall your app?
viktor-cli install
This should install the latest connector for you (which is v5.24.2), which should fix your problem.
Please let me know if this solves your problem.
@peter_vw Your error looks similar to the one I experienced. It turned out I wasn’t using the latest patch version of Python. I was stil on 3.10.8, while 3.10.11 was the latest 3.10 version.
Despite what @kvangiessen proposed in that topic, we later encountered exactly the same issue on a colleagues computer. That was also fix by upgrading 3.10.8 to 3.10.11.
But come to think of it: Maybe the viktor-cli install be both executed after installing the new Python patch version was the actual fix :thinking:
Thank you for your help! Updating the viktor connecter fixed the problem! I was using python 3.11 the whole time, so that was not the mistake I encountered. For me viktor-cli install was enough.
