I was about to report a bug, but found out that upgrading my Python 3.10.8 to 3.10.11 solved this issue. Maybe usefull to someone else
SDK: v14.9.0
Platform: v24.04.3
Python: v3.10.8
Isolation mode: venv
After updating an app from SDK 14.8.0 to 14.9.0, I get a ValueError for every API call we make. When I use this code from the docs:
api = API()
current_entity = api.get_entity(entity_id)
This ValueError is thrown
2024-04-12 22:01:25.479 ERROR :
File "viktor\parametrization.pyx", line 2343, in viktor.parametrization._SelectField._handle_options_constraint
File "%%%\app\design\parametrization.py", line 143, in _get_cross_section_design_names
File "viktor\api_v1.pyx", line 1102, in viktor.api_v1._API.get_entity
ValueError: `workspace_id` is required if API is initiated outside of a VIKTOR app.
Somehow the API doesn’t recognize this as a call from inside the app.
Expected the existing code to be compatible.
Was able to fix the behavior by upgrading Python to 3.10.11.
If you used Python from the Microsoft Store, update the patch version with the PowerShell command
winget install python.python.3.10and rebuild you venv.
