Add TableView
As a developer I want to be able to add a simple TableView so that I can quickly show tabular results to my users
I think this is relevant for the VIKTOR platform because tabular results are very frequent and there is not a very simple way to achieve this at the moment
provide a dedicated TableView
The current workarounds are quite nice, but:
Updated status to ā€œin-progressā€ since we have started the implementation on this.
The TableView has been released in the latest SDK release 14.13.0 :partying_face:
As easy as:
    @TableView("Student Grades", duration_guess=1)
    def table_view(self, **kwargs):
        data = [
            [128, "John", 6.9, False, date(1994, 6, 3)],
            [129, "Jane", 8.1, True, date(1995, 1, 24)],
            [130, "Mike", 7.5, False, date(1989, 12, 4)],
        return TableResult(data)
  • This makes it very easy to add tabular results in your app.
  • Default sorting and filtering
  • CSV download out-of- the box
  • Possibilities to style cells
Read more about it in the docs.
Looking forward to hear about your experiences @rvandijk , @rkg
Is it possible to add this table view to the word/pdf report?
It is possible to fill a table using the render_word_file function of the SDK. You can find information on how to do this here.
That only works when you know the cells where the values go into. I need to print a fairly large table that spans across multiple pages. Also the table dimensions itself is dynamic, so I can’t place a tag for each of the cell.
Current workaround of adding a plotly table as a figure in the word is a temporary fix for me, but since the table spans across multiple page, it clips off the portions of the table that can’t fit within page.
Is it possible to combine TableView with DataView?
UseCase would be raw data in table and summary in DataView
No that’s not possible at the moment.
Hello,
It seems that the CSV download option ignores non-numeric values.
In the example, it would download a CSV with blanks in the Names column and Boolean column.
Is there a way to download a CSV with all values?
Otherwise, can we hide this download button, as the data downloaded by the user would be incomplete?
Thanks
Hi @fzhou: thanks for reporting. We are aware of this issue and are implementing a fix that will make sure the values are included again. Will land in production soon
