Hi everyone,
For the last weeks, I have been building an application that uses some large python packages. When I use viktor-cli install
, the required packages are installed, and I can test my application in a test environment. However, when I want to push my code to github, I get the error:
GH001: Large files detected. You may want to try Git Large File Storage - https://git-lfs.github.com.
So, I tried using Git LFS, but without any success. I tried to track my files but that does not seem to work. I followed the ‘Getting started’ guide on https://git-lfs.com/.
Since I use a Macbook, I develop via gitpod.io, as recommended in VIKTOR’s documentation. When I use: git lfs migrate import
, (I’m unsure of what this does to be honest, but it was recommended as a fix), I get an permission denied error:
Unable to move /workspace/openSTEF/.git/lfs/tmp/1504205484 to /workspace/openSTEF/.git/lfs/objects/9c/4f/9c4f5fd95882379fe918eb9583d55a309f7c4a20c902170ef987bd6e584e9c2e
rename /workspace/openSTEF/.git/lfs/tmp/1504205484 /workspace/openSTEF/.git/lfs/objects/9c/4f/9c4f5fd95882379fe918eb9583d55a309f7c4a20c902170ef987bd6e584e9c2e: permission denied
Has anyone else any experience with this problem, and did someone find a solution for this problem?
Thanks in advance,
Ruben
