WebView interaction symbol
SDK: v14.x.x
Platform: v24.x.x
Python: v3.x
Isolation mode: venv/docker
When 1 web view with interaction is loaded, all other web views also get the interaction symbol even though they have no interaction.
afbeelding
Hi Luuk,
Could you share a minimal reproducible example of your implementation? I’ve tried reproducing it myself, but haven’t been able to reproduce the behavior you are describing.
Kind regards,
I am not sure how to get quickly an example. It happens when I run a view without interaction, it gives no interaction symbol (correct). Then I run afterwards a view with interaction and then both views get the interaction symbol (incorrect).
Great thank you for the additional information. That sequence indeed triggers it.
We will work on a fix
This is now fixed
