Viktor.geometry.points_are_coplanar is not correct
SDK: v13.0.0
the function viktor.geometry.points_are_coplanar seems not to be correct:
check_if_flat = points_are_coplanar([Point(x=0.0, y=0.0, z=0.0),
                NamedPoint(x=5.0, y=0.0, z=0.0),
                NamedPoint(x=5.0, y=5.0, z=5.0),
                NamedPoint(x=2.5, y=7.0, z=0.0),
                NamedPoint(x=0.0, y=5.0, z=0.0)])
should result in: False
→ the points are not in a (shared) two dimensional plane
This function should be 3D supported, because in 2D all points are coplanar by definition.
See before.
I would also expect some kind of numerical precision as input value.
I want to check if a surface is flat.
Thank you for the notification, I added the bug to our issue list.
This has been resolved in SDK v13.2.0
