SDK: v13.0.0
The function point_on_bounded line from viktor.geometry is not working in 3D space. Similar to: Intersection of lines in 3D space
See screenshot for some cases. This is not documented at all.
At very least explain in the docs that this is 2D (z=0) only and raise a ValueError when non z=0 values are used as input.
