After migrating to the new enviroment and configuring the viktor-cli I get the following error when installing the app. Any idea?
This is the folder it’s referring to:
Hi Bart,
Could you check out this thread? I think the solution is to move a native Python installation as first entry in your PATH variable: Creating virtual environment failed: Exiting because of an error: exit status 1 - #6 by rdejonge
Perfect! Installing Pyhton (even in the same Anaconda folder as it was) did the trick!
Thanks Raoul!
