When running a viktor-cli install I get the following error:
$ viktor-cli install
Creating app specific install dir signals
Creating virtual environment
Requirement already satisfied: pip in c:\users<user_provide><project>\venv\lib\site-packages (23.0.1)
ERROR: To use the truststore feature, ‘truststore’ must be installed into pip’s current environment.
ERROR:
Exiting because of an error: installation of the app failed
I suspect that this is due to the viktor-cli that was upgraded, but will have to check to make sure. I will keep you posted the moment I have more information.
Running on Windows, in venv isolation mode.
Python version used in 3.10.
Note that the python installation path used in viktor-cli configure point to a anaconda environment path.
Is there is a way to display more info from the command? I don’t see a verbose option on the install command
The CLI tries to upgrade pip to be able use the truststore feature. This is supported for python versions 3.10+, which is what we check beforehand. After that we run a pip upgrade command to get the latest version. From your logs it appears that no new version can be found. However, it should be available as can be seen from pip · PyPI.
Is the version of pip pinned to a specific version in your anaconda environment by any chance? Or is updating or installing Python packages in someway limited on your machine?
