Hi, I want to implement two GeoJSONViews in my app:
- A GeoJSONView with a duration guess of max. 3 seconds for quickly drawing a GeoPolyline
- A GeoJSONView with a duration guess of >3 seconds in order to activate the “update” button, as the user first needs needs to fill in all fields in the parametrization before something can be shown on the map. Also, the calculations take much longer.
Whether GeoJSONView nr. 1 or nr. 2 is chosen should depend on an OptionField from which the user selects an option. Is it possible to make the duration_guess parameter of the GeoJSONView dependent on a parametrization field value? Or is there a different, more suitable approach for this? Currently I’m forced to make to separate GeoJSONViews to achieve this, but from a user’s perspective this is very confusing.
