Using GeometrySelect with 3dm files
Hey there!
We would like to implement your newest feature of selecting a geometry in the 3d view and further process this in grasshopper. Because the grasshopper calculation can only be made when the “facade” is selected, we thougt of splitting the input (geometry and data) and selection and the output in two pages. But we are stuck at this stage. How do we define the pages in our controller and how do we make a geometryview that is only for selecting the facade without processing it? (processing should be done in the second page)
This is our state of the script:
from io import BytesIO
import json
import rhino3dm
import os
from viktor import ViktorController, File
from viktor.parametrization import NumberField, FileField, Text, Step, ViktorParametrization, OptionField, OptionListElement, ActionButton, GeometrySelectField, GeometryMultiSelectField
from viktor.external.generic import GenericAnalysis
from viktor.views import GeometryAndDataView, GeometryAndDataResult, DataGroup, DataItem
    intro = Text("## PV Machbarkeitsanalyse \n Das Script Level 1 berechnet den Ertrag der jeweiligen Input Fassaden Fläche \n\n Laden sie Ihre Fassadenfläche und Kontextgeometrien hoch und geben sie die vorgegebenen Parameter an:")
    # Input fields
    step_1 = Step("Stufe 1: Modellupload", ['run_grasshopper'])
    step_1.selected_geometry = GeometrySelectField("Wähle eine Fassadenfläche aus")
    step_1.selected_geometries = GeometryMultiSelectField("Wähle die Umgebungsgeometrie aus")
    step_1.Modell = FileField('Modell', file_types=['.3dm'], max_size=100_000_000)
    step_2 = Step("Stufe 2: Berechnung", views=['run_grasshopper'])
    step_2.Modultyp = OptionField('Modultyp', options=[OptionListElement('0', 'L 1300x875'),
                                                OptionListElement('1', 'Q 1300x720'),
                                                OptionListElement('2', 'M 985x875'),
                                                OptionListElement('3', 'S 985x720')], default=0)
    step_2.Eigenverbrauch = NumberField("Eigenverbrauch in % des Gesamtertrages", default=50)
    step_2.Investitionskosten = NumberField("Investitionskosten", default=10000)
    step_2.Instandhaltungskosten = NumberField("Instandhaltungskosten in % der Investitionskosten", default=2.0)
    step_2.Foerderbeitrag = NumberField("Förderbeitrag %", default=6)
    step_2.Strompreis = NumberField("Strompreis(Fr./kWh)", default=1.0)
    step_2.Einspeiseverguetung = NumberField("Einspeiseverguetung(Fr./kWh)", default=1)
    step_2.Zeitraum = NumberField("Zeitraum(Jahre)", default=5)
    label = 'My Entity Type'
    parametrization = Parametrization(width=30)
    @GeometryAndDataView("Geometry", duration_guess=0, update_label='Run Grasshopper')
    def run_grasshopper(self, params, **kwargs):
        rhino_upload = params['Modell'].file
        selected_geometry = params.selected_geometry
        selected_geometries = params.selected_geometries
        # Read the rhino file
        gh_file = rhino3dm.File3dm.FromByteArray(rhino_upload.getvalue_binary())
        facade = selected_geometry
        context = selected_geometries
        encoded_facade = []
        encoded_context = []
        # Durchlaufen aller Objekte und Kodieren der zum gewünschten Layer gehörenden
        for obj in gh_file.Objects:
            if facade:
                geom = obj.Geometry
                # Kodieren des Geometrieobjekts
                encoded_data = json.dumps(geom.Encode())
                encoded_facade.append(encoded_data)
            if context:
                geom = obj.Geometry
                encoded_data2 = json.dumps(geom.Encode())
                encoded_context.append(encoded_data2)
        # Erstellen einer JSON-Datei aus den Eingabeparametern
        #new dictinary
        params.pop("Modell")
        params['encoded_facade'] = encoded_facade
        params['encoded_context'] = encoded_context
        input_json = json.dumps(params)  # Konvertieren aller Parameter inklusive der Geometrie in JSON
        print(params)
        # Erstellen der Eingabedateien für die Analyse
        files = [
            ('input.json', BytesIO(bytes(input_json, 'utf8'))),
        # Run the Grasshopper analysis and obtain the output files
        generic_analysis = GenericAnalysis(files=files, executable_key="run_grasshopper", output_filenames=[
            "geometry.3dm", "output.json"
        generic_analysis.execute(timeout=60)
        rhino_3dm_file = generic_analysis.get_output_file("geometry.3dm", as_file=True)
        output_values: File = generic_analysis.get_output_file("output.json", as_file=True)
        # Create a DataGroup object to display output data
        output_dict = json.loads(output_values.getvalue())
        print(output_dict)
        data_group = DataGroup(
            *[DataItem(key.replace("_", " "), val) for key, val in output_dict.items()]
        return GeometryAndDataResult(geometry=rhino_3dm_file, geometry_type="3dm", data=data_group)
Thanks for your help!
Hi @Broesmeli,
To use the GeometrySelect with 3dm-files, you will have to fill in the Name of a mesh:
Your GeometrySelectField will then return ‘This is the identifier’.
To retrieve only this mesh from a model you are on the right track; you indeed loop over all objects and compare the name in attributes:
# Read the rhino file from your upload
rh_file = rhino3dm.File3dm.FromByteArray(
    params.step_1.rhino_upload.getvalue_binary()
# Prepare output list
encoded_facade = []
# Iterate over all objects
for rhino_object in rh_file.Objects:
    if params.step_1.selected_geometry == rhino_object.Attributes.Name:
        # Encode and add to list
Extra: Generating 3dm geometries compatible for geometry select
This also works the other way around; if you don’t have a 3dm file to start with. You can create meshes yourself, and create ObjectAttributes and add a identifier to the Name value. The GeometrySelectField will then return that identifier when you select it.
Regarding your question on how to build this into multiple steps; I’d suggest creating 2 views, and assigning the choose_geom view only to the first step, and your Grasshopper definition in the second one. Your view can look like this:
@GeometryView("Choose Geometry", duration_guess=0, x_axis_to_right=True)
def choose_geom(self, params, **kwargs):
    return GeometryResult(geometry=params.step_1.Modell.file, geometry_type="3dm")
Hopefully this comment helps you out!
Hey @rvandijk
Perfect, now we are a step further :slight_smile: The geometry selection works and we got 2 separate steps now, yeah!
Now that we splitted up the import and selection (GeometryView) from the data input (GeometryAndDataView) we got a problem with the “rhino_upload”. We think that we mixed up the steps a little bit.
Can you maybe help us out again …?
Most recent error:
  File "viktor_connector\\connector.pyx", line 302, in connector.Job.execute
  File "viktor\core.pyx", line 1940, in viktor.core._handle_job
  File "viktor\core.pyx", line 1925, in viktor.core._handle_job._handle_view
  File "viktor\views.pyx", line 2053, in viktor.views.View._wrapper
  File "D:\Programme\Viktor\viktor-apps\pv-app\app.py", line 59, in run_grasshopper
    if params.step_2.selected_geometry == rhino_upload.Attributes.Name:
  File "D:\Programme\Viktor\viktor-apps\pv-app\venv\lib\site-packages\munch\__init__.py", line 121, in __getattr__
    raise AttributeError(k)
AttributeError: selected_geometry
Complete app.py - code:
import json
import rhino3dm
from viktor.parametrization import NumberField, FileField, Text, ViktorParametrization, Step, OptionField, \
    OptionListElement, GeometrySelectField, GeometryMultiSelectField
from viktor.views import GeometryAndDataView, GeometryAndDataResult, DataGroup, DataItem, GeometryView, GeometryResult
    step_1 = Step('Modell_Modultyp', views='choose_geom')
    step_1.intro = Text(
    # Input fields
    step_2 = Step('Angaben', views='run_grasshopper')
        rhino_upload = params.step_1['Modell'].file
        encoded_facade = []
                geom = obj.Geometry
            if params.step_2.selected_geometries == rhino_upload.Attributes.Name:
                geom = obj.Geometry
        # new dictinary
        params.step_2.pop("Modell")
        print(params)
        files = [
        print(output_dict)
        return GeometryAndDataResult(geometry=params.step_2.rhino_3dm_file, geometry_type="3dm", data=data_group)
Step_1:
Step_2:
Thank you so much, really appreciate your support!
Hi @Broesmeli ,
selected_geometry and selected_geometries are part of step_1, so while looping through the gh_file.Objects, you will have to reference step_1 in stead of step_2.
Hopefully that helps out!
That should be it. Thank you!
hey @rvandijk,
We have a problem with the calculation of the yield output. When we calculate our facade without context geometry we get the same result in the local script as in the viktor interface. When we calculate the yield with context in our local script the yield is correct. But when we connect our script with viktor the yield value is incorrect. So we think the context geometry is in our calculation not included, maybe in the app.py script we got something wrong.
here the outcomes of the local script and the viktor interface:
here is our app.py code:
import json
import rhino3dm
    # Input fields
    @GeometryView("Geometry", duration_guess=0, x_axis_to_right=True)
        encoded_facade = []
            if params.step_1.selected_geometry == obj.Attributes.Name:
                geom = obj.Geometry
            if params.step_1.selected_geometries == obj.Attributes.Name:
                geom = obj.Geometry
        # new dictinary
        params.step_1.pop('Modell')
        params.step_1['encoded_geometry'] = encoded_facade
        params.step_1['encoded_geometry2'] = encoded_context
        input_json = json.dumps(params.step_1)  # Konvertieren aller Parameter inklusive der Geometrie in JSON
        print(params)
        files = [
        params.step_1.rhino_3dm_file = generic_analysis.get_output_file("geometry.3dm", as_file=True)
        print(output_dict)
        return GeometryAndDataResult(geometry=params.step_1.rhino_3dm_file, geometry_type="3dm", data=data_group)
cheers samuel & Marco
Hi Samuel & Marco,
What does params print here?
Things are looking good here, it might be difficult to debug without further insights.
Rick
Hi Rick,
We are getting this message in our PowerShell:
2024-09-05 19:12:46.292 INFO    : Job (uid: 984461) received - EntityType: Controller - call: run_grasshopper
Munch({'step_1': Munch({'selected_geometry': 'Fassade', 'selected_geometries': ['Context', 'Context', 'Context', 'Context', 'Context', 'Context'], 'encoded_geometry': ['{"version": 10000, "archive3dm": 60, "opennurbs": -1877177544, "data": "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"}'], 'encoded_geometry2': []}), 'step_2': Munch({'Modultyp': 0, 'Eigenverbrauch': 50, 'Investitionskosten': 10000, 'Instandhaltungskosten': 2, 'Foerderbeitrag': 6, 'Strompreis': 1, 'Einspeiseverguetung': 1, 'Zeitraum': 5})})
From this print it seems that ‘encoded_geometry2’ is empty; therefore no geometry is sent over to Grasshopper and no result is produced.
Looking back at your example, the issue probably is in the encoded_context.
The selected_geometries returns a list of selected attribute names (e.g. [A, B, C]), so you are comparing that list to the objects Attributes. Probably the fix here is to do:
if obj.Attributes.Name in params.step_1.selected_geometries:
Rick
Hi Rick,
Thanks alot, now it works :slight_smile:
