Using default data-files (publishing-file-folder)
Hi Dev team,
Today i tried publishing my first app, unfortunately it doesn’t work yet.
The app will read csv files from a filefolder ‘corefiles’ inside the appfolder, but when published it cant find the files. I did try the -–use-filesystem flag like discussed in https://community.viktor.ai/t/error-while-publishing-an-app/
Is it possible also publish my -corefile- map with csv files in it? or would i have to rewrite it to a dictionaries/lists?
Kind Regards,
Nino
Hi Nino,
Thanks for your question. The case you described should be possible. Could you check whether you refer to the csv files with relative imports? For more information regarding this, refer to the following:
Thanks! this works:D
