To control the visibility of parameters inside a DynamicArray, I have to use a RowLookup
. The problem that I encounter is that it does not seem to work within an IsEqual
function. If I look at the IsEqual documentation, it also does not seem to be supported. I do however not get any error indicating that it is not supported which is something I would expect.
Below a code snippet of how I use the IsEqual in the parametrization.
parameters.length = NumberField("Lengte", flex=50, default=0, suffix="m", min=0, visible=IsEqual(RowLookup('shape'), RECTANGULAR))
Am I doing something wrong or is RowLookup really not supported inside an IsEqual
