In order to upload a file to a S3 bucket I need a file path. How can I get a file path from a file that I uploaded via a Viktor file upload field? Or are there other possibilities to do this?
KR.
Jan
KR.
Jan
Hi Jan,
To upload a file to S3, what do you need specifically?
I will assume you need a local path to the file. You can generate a temporary file to save the content to, and then pass that filename to the s3 uploader:
import os
from tempfile import NamedTemporaryFile
def upload_file_to_s3(params, **kwargs):
# params.file_to_upload represents the file to be uploaded to s3
tmp_file = NamedTemporaryFile(delete=False)
# Write the binary content of the file to the temporary file
tmp_file.write(params.file_to_upload.file.getvalue_binary())
tmp_file.close()
# Now upload the file to s3
s3_client.upload_file(file_name=tmp_file.name, ...)
# Don't forget to remove the temporary file
os.unlink(tmp_file.name)
Please let me know whether this solves your issue!
