Updated Map
Hi, I am using a Map in one of my applications. However, the map does not show street names in much detail. The area I’m viewing is the Caribbean (Bonaire and St. Lucia to be specific). Is there a way to link the most recent Google Maps map or other source to the Viktor MapView?
Hi @janvandinther ,
There isn’t a direct way to change the MapView’s map (other than Satellite view).
We are currently working on implementing WebView interaction, so that these specific Views could potentially be made. I will update this thread, once that has been released.
Hopefully that helps out!
One option that might be worth some investigation is using Folium in a WebView. Afaik you can specify a default tileset on Folium maps, although some options would require a (paid) token.
