SDK: v13.7.0
Platform: v23.02.2
Python: v3.10
Isolation mode: venv
When having multiple views in a step, the order of these views is determined based on the order they are implemented in the controller class. For example, the following code:
visualization = Step(
"Visualization",
views=["first_tab", "second_tab", "third_tab"],
previous_label="Previous step",
next_label="Next step",
will result in the following order of views:
just because âthird_tabâ is implemented first in the controller class, âsecond_tabâ next and âfirst_tabâ last like this:
@GeoJSONView("Third tab", duration_guess=3)
def third_tab(self, params, **kwargs) -> GeoJSONResult:
@PlotlyView("Second tab", duration_guess=10)
def second_tab(self, params, **kwargs) -> PlotlyResult:
@PlotlyView("First tab", duration_guess=3)
def first_tab(self, params, **kwargs) -> PlotlyResult:
If I change the order in the controller class, I can get the order I want to show in the application. This might work for one step, but imagine having multiple steps with multiple views. At some point it would become impossible to get the desired order for every step.
P.S. I havenât checked this for a âPageâ. I guess the behaviour would be simillar.
It seems more logical to me to actually see the order as given in the parametrization, so that:
would result in:
