UI/UX Feedback
As a user I want more flexibility in the UI. Below is some feedback:
  • The UI is not flexible enough for complex apps compared to desktop options or compared to Streamlit.
  • A lot of times people have to make workarounds that are “annoying”, such as:
    • calls in the parametrization when they’re linked with each other when a user needs a field to be dependent on another field, but the callback might be a bit slow due to external API
    • vkt.InputTable vs Table in the controller. Why do we need two types of tables. Should just be one table where you can do inputs, perform logic, and show results
Arup developer
None
First point related to this feature:
