TypeError: _handle_job() takes exactly 1 positional argument (5 given)
Hi all, i had viktor version 13.2.1 and everything was working just fine, but after trying to update to the lastest version (13.8.0), an error appear when i try to open an entity in development. i have a ‘simple’ app-type
I updated viktor activating the venv with this command
venv\Scripts\activate
and then typing this command:
pip install --upgrade viktor
pip showed that the upgrade was successful. This are the packages that i have installed:
Package           Version
asttokens         2.2.1
backcall          0.2.0
colorama          0.4.6
contourpy         1.0.5
cycler            0.11.0
decorator         5.1.1
et-xmlfile        1.1.0
executing         1.2.0
fonttools         4.37.3
ipython           8.7.0
jedi              0.18.2
plotly            5.10.0
prompt-toolkit    3.0.33
pure-eval         0.2.2
Pygments          2.13.0
pyparsing         3.0.9
python-dateutil   2.8.2
python-docx       0.8.11
pytz              2022.2.1
setuptools        63.2.0
six               1.16.0
stack-data        0.6.2
tenacity          8.0.1
traitlets         5.6.0
viktor            13.8.0
viktor-connector  5.17.1
wcwidth           0.2.5
But after running
viktor-cli start
This error appear when try to open an entity like in the first image:
  File "viktor_connector\connector.pyx", line 323, in connector.Job.execute
  File "viktor\core.pyx", line 1780, in viktor.core._handle_job
I have a long project with multiple views and inputs, so i will put a resume of the code:
import pandas as pd
import numpy as np
import plotly.graph_objects as go
import traceback
from utils_funcs import *
from viktor.parametrization import (
    ViktorParametrization,
    NumberField,
    Tab,
    Section,
    DownloadButton,
    TextField,
    DateField,
    FileField,
    MultiSelectField,
    OptionField,
    IntegerField,
    Table,
    ToggleButton,
    Lookup,
    FunctionLookup,
    BooleanField,
    IsTrue,
    IsFalse,
    And
from viktor.views import GeometryView, GeometryResult, PlotlyView, PlotlyResult
from viktor.core import Storage, File
from viktor.errors import UserError, InputViolation
from viktor.utils import convert_word_to_pdf
from viktor.result import DownloadResult
import funciones
import os
import time
from pathlib import Path
import utils_funcs
from io import BytesIO
    tab_p = Tab("Project")
    tab_p.section_1 = Section("General Information")
    tab_p.section_1.project_name = TextField("Project Name")
    tab_p.section_1.location = TextField("Location")
    tab_p.section_1.contractor = TextField("Contractor")
    tab_p.section_1.front_page_image = FileField("Front Page Image", file_types=[".png", ".jpg", ".jpeg"], max_size=5_000_000)
    tab_p.section_2 = Section("Report Version")
    viktor_enforce_field_constraints = True
    label = "Geomastic App"
    @PlotlyView("Loads", duration_guess=3)
    def boxplots_fuerzas(self, params, entity_id,  entity_name, **kwargs):
        try:
            es_calculo_cimentacion_profunda = params.tab_2.section_1.cimentacion_profunda
            formato_servicios = [list(fila.values()) for fila in params.tab_2.section_3.inputs]
            servicios_dataframe = pd.DataFrame(data=formato_servicios,
                columns=[
                    "joints",
    @PlotlyView("Moments", duration_guess=3)
    def boxplots_momentos(self, params, entity_id,  entity_name, **kwargs):
        try:
                columns=[
    @PlotlyView("Basic", duration_guess=25)
    def capacidad_portante_asentamientos(self, params, entity_id,  entity_name, **kwargs):
        try:
            es_calculo_pilotes_personalizado = params.tab_2.section_pilotes.es_calculo_pilotes_personalizado
            (   servicios_dataframe,
                perfil_dataframe,
                modelacion_dataframe,
                personalizacion_dataframe,
                B,
                L,
    @PlotlyView("Differential", duration_guess=240)
    def asentamientos_diferenciales(self, params, entity_id,  entity_name, **kwargs):
        try:
                perfil_dataframe,
    @PlotlyView("Construction", duration_guess=120)
    def dimensiones_construccion(self, params, entity_id,  entity_name, **kwargs):
        try:
                perfil_dataframe,
    @PlotlyView("Interaction", duration_guess=85)
    def interaccion_suelo_estructura(self, params, entity_id,  entity_name, **kwargs):
        try:
                perfil_dataframe,
    @PlotlyView("Costs", duration_guess=480)
    def visualizar_presupuesto(self, params, entity_id,  entity_name, **kwargs):
        try:
    @GeometryView("3D", duration_guess=240)
    def render_cumplimineto(self, params, entity_id,  entity_name, **kwargs):
        try:
    @PlotlyView("Optimization", duration_guess=540)
    def precio_vs_costo(self, params, entity_id,  entity_name, **kwargs):
        try:
There are more views but they follow the same pattern.
You can update viktor by modifying requirements.txt and call viktor-cli install. See also Fundamentals - Upgrade VIKTOR version | VIKTOR Documentation
Thanks, after re installing everything works fine.
