Hi, my Parametrization contains several input fields and a SetParamsButton. This button retrieves values from a loaded .csv file to use as new input for the input fields. When I change a specific field (a OptionField isn this case), I need to click the SetParamsButton manually. I would like a way to automate the call of the set_param_a function with the change of the mentioned OptionField, is that possible?
Currently it is not possible to trigger a custom callback function on changing a field. However, it is permitted to use callbacks in certain usecases in parametrization. For example to dynamically set the allowed options on an OptionField. If a callback does not solve your problem, could you describe the behaviour you would like to see in more detail? Then I will flag this as a Feature Request.
I know this is an old topic, but I think I got the same question.
When I choose a different option from the options, does not matter which option, I want to trigger a set params to instantly fill a table.
Why?:
I got 2 tables and the option field decides which one i see, but i want to transfer some filled in data to the other table when i switch tables and i do not want my user to have to do this manually pressing a button (because this is unintuitive behavior)
I do not think this is possible yet and probably a feature request.
