Too much memory was used bug
Hi all,
We have updated the platform with a fix.
  • New reported errors should now show the correct error stack trace
  • Old reported errors can unfortunately not be recovered
Please do not hesitate to contact us in case the “too much memory” error occurs, as this can still be a valid error!
Hello,
I have this issue again.
Do you have any recommandations ?
Thank you
Hi @LM_Vin ,
My recommendation would be to check where the memory usage is the most, as described in this thread by my colleague:
If, after the evaluation, you conclude that there are no changes that will significantly help reduce the memory, please let me know.
