the title speaks for itself.
As the dynamo nodes are developed to adres the information stored in an app, it a logic step that the storage functionality can be adressed as well.
@Tom_Nillesen thanks for taking the time to let us know! I have bumped our internal issue tracker.
@Tom_Nillesen could you please check whether this feature request is related to this one: Viktor dynamo plug-in - #3 by sonomirco
If it is related, can you please add your use case there? Furthermore, it helps if you can upvote that issue such that it gets a higher priority.
This is indeed the same issue, however the solution does not work for me as a large amount of data in a hiddenfield slows down the editor too much.
