I really like the new Table view, there is only one thing i get this error:
2024-07-17 14:51:00.075 ERROR : Result can not be serialized to JSON: Out of range float values are not JSON compliant
I think it is because my pandas dataframe is to large(400 rows), is possible to still show this, and what is the max size of the dataframe?
I thought it had to do with max values but the dataframe is not allowed to take Nan value, when using this line it is fixed:
df = df.fillna(“”)
Hi Luuk,
Good to hear you like the new TableView. I expect Nan to work. Do you also get the error with this simple TableView?
@TableView("Table View", duration_guess=1)
def table_view(self, **kwargs):
df = pd.DataFrame([[1, np.nan], [3]])
return TableResult(df)
The TableView works with np.nan. But not all NaNs are made equal. There certain NaN fillers that can not be JSON serialised. Als np.inf will trigger this error.
Btw: The issue with a dataset > 100 rows not showing is fixed in SDK v14.15.0
