As a developer I want to that a GeoPolygon object supports multipolygons so that more complex shapes can be visualized in a mapview
I think this is relevant for the VIKTOR platform because multipolygons are a common feature. For example, a hole in a polygons results in a polygon (an exterior polygon with an interior polygon). See example below with a grey polygon with a hole in it.
None
None
Hi Vincent,
Thank you for writing up this feature request. Could you maybe elaborate a bit more on why you are experiencing the lack of multi polygon support as a limitation? What are you trying to achieve, but cannot do without this functionality? This way we can understand the use case better.
Kind regards,
Hey, sure. Take a look at the screenshot below. The blue polygon is the exterior of a polygon. The black polygons are supposed to be holes in the polygon.
In the second image, I have a true multipolygon. You have 1 blue exterior polygon. In that, there are several holes (black). Some of these holes contain another polygon (blue).
The viktor GeoPolygon object only supports the exterior of a polygon, and thus holes (and more feature in that hole) are not possible.
@Vincentvd we don’t have multipolygon support for the MapView i believe, but it is supported on the GeoJSONView
there are a whole lot of brackets to keep track of, but this seem to work
@GeoJSONView('GeoJSON View', 1)
def get_geojson_view(self, params, **kwargs):
geojson = {
"type": "FeatureCollection",
"features": [
"type": "Feature",
"properties": {},
"geometry": {
"type": "MultiPolygon",
"coordinates": [
-47.900390625,
-14.944784875088372
-51.591796875,
-19.91138351415555
-41.11083984375,
-21.309846141087192
-43.39599609375,
-15.390135715305204
-47.900390625,
-14.944784875088372
-46.6259765625,
-17.14079039331664
-47.548828125,
-16.804541076383455
-46.23046874999999,
-16.699340234594537
-45.3515625,
-19.31114335506464
-46.6259765625,
-17.14079039331664
-44.40673828125,
-18.375379094031825
-44.4287109375,
-20.097206227083888
-42.9345703125,
-18.979025953255267
-43.52783203125,
-17.602139123350838
-44.40673828125,
-18.375379094031825
return GeoJSONResult(geojson)
I indeed saw that. But, you can’t draw on a GeoJsonView right? We use a MapView to both ask for input (GeoPolygonField) and visualize input.
You can also draw on the GeoJSONView. Actually the MapView is just a convenience layer on top of the GeoJSONView (easier objects).
As a side note: Could the drawing on GeoJSONView be appended to the documentation? It now only states MapView. See GeoPointField, GeoPolylineField, GeoPolygonField in the SDK and Map features.
