Hey everyone!
For this week’s Snippet Wednesday I have a small app that activates audio and a GIF in the WebView.
what is this useful for?
Let’s say you would like to add some more, dynamic content that is limited by html, then you can use CSS and Javascript to extend your functionality.
This app has an audio player and dynamic GIF to show you how it done. The app will hide the GIF when the audio is not playing.
what you will need to add to your app folder:
- You will need an awesome piece of audio to add to your app
- A cool GIF to add to your application
full code
The full functional app-code for this example can be found here:
from viktor.parametrization import ViktorParametrization, SetParamsButton, BooleanField
from viktor.result import SetParamsResult
from viktor.views import WebView, WebResult
import base64
from pathlib import Path
from io import StringIO
def base64_encoding(data: bytes):
return base64.b64encode(data).decode()
make_web_view = SetParamsButton('🦄 Click here to activate 🦄', method='set_html', flex=100)
boolean_html = BooleanField('show content', default=False, visible=False)
label = 'audio demonstration app'
@WebView('Audio player', duration_guess=1)
def get_gif_view(self, params, **kwargs):
audio_path = Path(__file__).parent / 'my_awesome_audio.mp3'
gif_path = Path(__file__).parent/'giphy.gif'
with open(audio_path, 'rb') as f:
audio = base64_encoding(f.read())
with open(gif_path, 'rb') as file:
gif_data=base64_encoding(file.read())
if not params.boolean_html:
html_string = f'''
<!DOCTYPE html>
<html>
</html>'''
else:
html_string = f'''
<!DOCTYPE html>
<html lang="en">
<head>
<meta charset="UTF-8">
<meta name="viewport" content="width=device-width, initial-scale=1.0">
<title>Audio with GIF</title>
<style>
#gif {{
display: none;
</style>
</head>
<body style="height:100%;">
<audio id="audio" controls autoplay>
<source src="data:audio/mp3;base64,{audio}" type="audio/mpeg">
Your browser does not support the audio element.
</audio>
<img id="gif" src="data:gif_data/gif;base64,{gif_data}" alt="Playing GIF" style="display: block;width: 65%;">>
<script>
// Get references to the audio and GIF elements
const audio = document.getElementById('audio');
const gif = document.getElementById('gif');
// Add an event listener to the play button of the audio player
audio.addEventListener('play', () => {{
gif.style.display = 'block';
// Add an event listener to the pause button of the audio player
audio.addEventListener('pause', () => {{
// When pause is clicked, hide the GIF
gif.style.display = 'none';
</script>
</body>
</html>'''
return WebResult(html=StringIO(html_string))
def set_html(self):
return SetParamsResult({
"boolean_html": True
The result will amaze you
