Is there a way to make a field visible when another field is smaller or larger than a particular value? In my case, I only want to make field 2 visible when field 1 is smaller than 7.
Cheers,
Marieke
Cheers,
Marieke
Hi Marieke,
Good question, and yes this is very much possible.
You can make use of a βcall-back functionβ. A minimum working example of what youβre trying to do would look something like:
from viktor.parametrization import NumberField, Parametrization, Text, FunctionLookup, Lookup
def height_threshold(height, **kwargs):
if height > 40:
return True
return False
class Parametrization(Parametrization):
length = NumberField('Length (L)', suffix='mm', default=10)
width = NumberField('Width (W)', suffix='mm', default=10)
height = NumberField('Height (H)', suffix='mm', default=10)
text = Text("Your height is getting quite disproportional!!!", visible=FunctionLookup(height_threshold, Lookup("height")))
Let me know if that helps!
It works, thanks!
