Hi Support,
I try to show a selected value from a OptionField in the summary of an entity. However, the app gives a definitionerror: Parametrization summary item classification_status originates from param of type select, expects type from: text
Do you have any idea how to fix this?
Hi Bart,
Could you show the code of how you are trying the access the optionfield?
It should be something like this:
from viktor.parametrization import ViktorParametrization, OptionField
optionfield_sample = OptionField('This is an OptionField', options=['A', 'B'], default='A')
def some_function(self, params, **kwargs):
print(params.optionfield_sample)
Hi Jelle,
It is more something like this:
summary = Summary(
item_1=SummaryItem('Length', str, 'parametrization', ' optionfield_sample')
Hi Bart,
Unfortunately, OptionFields are currently not supported in the Summary.
Fields that are supported are:
- NumberField
- IntegerField
- TextField
Ref to docs
Current workaround is to create a DataResult view and show the results there instead.
I hope this answers your question.
