A use case where table with many columns, but the first two are the most relevant. Similarly to Excel, the table should pin the first two columns, with all other columns being scrollable from left to right.
This would be good for us because in our use case we have one column containing questions, then 2 other columns containing simple “Yes”, “No”. Ideally we do not need so much space for the Yes No columns by default. The user always has to adjust the column manually to see the full text.
Or maybe if there is text wrapping for a column for long text. That would also be good.
