The FreeSurface load
model.create_free_surface_load(
name=f"EG {transformer_unit.name}",
load_case=load_case,
direction=scia.SurfaceLoad.Direction.Z,
q1=-load * KN_TO_N, # Negative to point the force downwards in the GCW in Scia
distribution=FreeSurfaceLoad.Distribution.UNIFORM,
points=[(surface_vertex.x * MM_TO_M, surface_vertex.y * MM_TO_M) for surface_vertex in surface_vertices],
This should generate the free surface load on all slabs in z direction. However it gets added to z=0 .
This shouldn’t be the case. Is this due to Scia v24 or due to updates in de SDK?
Becuase it means all results with free surface loads have become invalid.
