Scia Engineering Report Syntax invalid
SDK: v14.x.x
Platform: v24.x.x
Python: v3.x
Isolation mode: venv/docker
This should not be placeholders. But the values.
Any idea what causes this? I think it is related to v25
Hi Johan,
Thanks for reporting this. Could you provide more context.
@khameeteman do you maybe know what is going on here?
Sorry the image was pasted in the commented section….
Basically we updated the v24 to v25 a while ago. But when i generate an Engineering Report it doesn’t render the Headings well.
It happend with two different .esa templates. (Different files, different templates, different authors)
So I think it is a generic issue with v25.
I think you might be right.
In the end the VIKTOR worker is just executing a command using SCIA’s esa_xml program, so it indeed looks like an issue with v25.
Could you confirm this is not related to the Viktor SDK? Because if that is the case, we need to contact Scia.
It would be great if you could do so if you have the contacts.
I will try to look for some contact on our side.
