Hi guys, I can’t seem to find where to change the option for a mindlin or kirchhoff calculation when making a SCIA engineer model. Any idea?
Setting the solver setup is currently not supported in the SCIA binding and is currently not worked on. I added your request. You might be able to set it in the XML input file manually though.
This has been added in SDK v13.1.0
