I’m trying to add an arrow at the center of a polygon.
Is it possible to rotate an icon, according to a rotation angle from the parametrization.
If it is not possible to rotate an icon, is there another way to add an arrow according to a certain parameter?
              Hi Pieter,
As far as I’m aware there is no current functionality for rotating MapPoint icons. The only wild workaround I could think of is to automatically have an arrow-shaped polygon be drawn on the map once the user selects their own input and assign a specific color to that polygon so it may look a bit like an indicator. Though that doesn’t sound very convenient.
I assume that your use-case for rotating the icon would be to indicate something like the direction of the facade of a building, am I correct? In that case I can mark this post as a Feature Request to see if other users have similar needs.
