RFEM Parallelization / Licenses required
In the documentation section for Supported Integrations, it is said that the number of licenses required to use RFEM is unknown.
Our team would like to confirm whether licenses are required or not for RFEM (a software that typically require a license to be used). If they are required, is there more information available about the number of licenses required?
Hi @kassi,
RFEM indeed requires a license as it would when using the program through the UI. However, I am not certain whether RFEM supports executing multiple worker jobs in parallel and if it would support that whether that would require multiple license seeds.
