Restart of client during processing lot of points Mapresult
SDK: v14.22.0
Platform: v26.02.5
Python: v3.13
Isolation mode: venv
For example mapresult processes 79419 records. I see the following console log.
2026-03-02 10:04:00.582 INFO : Processed 79419 records from features
2026-03-02 10:04:00.681 INFO : Created DataFrame with columns: [‘NAME’, ‘TSTAMP’, ‘LATITUDE’, ‘LONGITUDE’, ‘SOG’, ‘datetime’, ‘geometry_wkt’]
2026-03-02 10:04:07.329 INFO : Job (uid: 148388) completed successfully in 10332ms
2026-03-02 10:04:11.747 WARNING : Connection is closed
2026-03-02 10:04:15.626 INFO : Could not connect, retrying in 1 seconds
2026-03-02 10:04:16.632 INFO : Connecting to herik.viktor.ai…
2026-03-02 10:04:16.899 INFO : Connection is established (use Ctrl+C to close)
Mapview shows the points in a map
This app shows points in a map. Showing the data in table goes well.
The problem appears in processing more than 450000 points.
This is interesting, I’ll connect you to our infrateam.
Could you also verify if the MapView has some sort of Interaction available?
Rick
