Publish a new version of an app
Hello,
I was published my first app as v0.1.0
After that I added new features the app and tried to publish new version as v0.1.3 - 0.1.4 - 0.1.5
Before the publishing for sure I tested the app into the local workspace and I did not get any error. But when I am trying to open the app I got an error message.
Then I updated the app codes according to first publishing codes to be sure what is the problem but I am still getting an error message even if I used the first published codes.
Everything look like fine but I did not find the problem that occurred the error.
Hi Hakan,
Thank you for the elaborate message. We will look into this case and get back to you asap.
Kind regards,
Hi Raoul
Thanks for your anwser.
Best Regards,
It seems that something went wrong internally at our side, this is now resolved and your app is running again.
Raoul,
Thanks for the quick reply and solution!
Dear Raoul,
When I updated the app, I had faced the same problem. Is it occurred cause of my any fault or anything else?
Hi Hakan,
It seems the app is running into a memory limit. My colleague @dsommers will contact you to look into this further.
