Possibility to add newlines to table headers
As a developer want to add newlines to parametrisation table headers so that tables are more readable.
I think this is relevant for the VIKTOR platform because there are often cases where the tables contain only numbers, so the fields do not need to be very wide. But due to the fact the column name is very long, you can no longer see your table all at once, making it very messy.
Allow the used to include newlines ā€œ\nā€ where they would like a line break
Using acronyms or abbreviations for the names of the table headers, but that can make the app less user friendly
related topic: Latex in table column names
Related topic: Style / format text using Markdown in TableInput
Bump of this issue.
If it would be easier, I would also be helped with:
  1. the tooltip option which is available at Table level to also be available for individual columns. I would say this is already included as TextField also has a description parameter, but this does not seem to work in Table.
  2. column widths that can be changed dynamically by the user
