So we use a lot of webview (like 90% of the views are WebViews) and we make use of the Plotly figures using the cdn to avoid long reloadings.
This works perfectly fine if you change a number value. But if you use a togglebutton the view gets stuck on reloading. Nothing happens.
You can fix this by changing a numberfield for instance or another option.
The difficult thing is, it doens’t always result in this delay… but if it doesn, it just gets stuck forever.
Just for debugging: VIKTOR at 6:51 AM
Hi Johan,
Thank you for reporting. Could you share a minimal reproducible example? I tried with the following code both local and after publishing but I cannot reproduce. Am I missing something?
number = vkt.NumberField("Number")
cdn = vkt.BooleanField("CDN")
@vkt.WebView("Plotly")
def get_view(self, params, **kwargs):
import plotly.express as px
fig = px.scatter(x=[0, 1, 2, 3, 4], y=[0, 1, 4, 9, 16])
if params.cdn:
data = fig.to_html(include_plotlyjs="cdn")
else:
data = fig.to_html()
return vkt.WebResult(html=data)
Kind regards,
In theory it should contain the same logic, however this view isn’t in isolation.
So sadly i do not have a snippet or something simular.
But as I saw it appear, I thought, better to report, so you if other people (or us) experience it again, it might be easier to reproduce / fix it.
Could you elaborate on what you mean by this? Does it happen across multiple views? Or only on a specific (web)view?
