Hi all,
I was wondering how you can easily create a Pandas dataframe from a table in parametrization. I tried to use the following:
table = params.table
df = pd.read_json(table)
This however does not work. Does any of you know what to do?
Cheers!
Hi all,
Cheers!
Hi Jelle,
I’m glad you are asking this question, as this (I think), is something that a lot of developers encounter. As a VIKTOR table is simply a list of dictionaries, it should be as easy as simply doing the following:
import pandas as pd
df = pd.DataFrame(table)
Other approaches are also discussed in this StackOverflow link: python - Convert list of dictionaries to a pandas DataFrame - Stack Overflow
I hope this helps.
