Overlapping an image to a map
As a developer, I would like to be able to overlap images on the map.
Here is an example.
I would like to show a borehole map.
The relevant WMS query map is in PNG format that I would like to overlay on the map.
I think this is relevant for the VIKTOR app to expand the number of information can be visualized on a map.
Alternatively - I could run ~50 WMS queries to GetFeatureInfo and then take the union set of all the results and visualize the point location with a marker, rather than running a single WMS query to get a map image like [this one].(https://map.bgs.ac.uk/arcgis/services/GeoIndex_Onshore/boreholes/MapServer/WmsServer?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=0.09112930985183294308,52.20153900519193968,0.09975104018012376228,52.20843219438115312&CRS=CRS:84&WIDTH=1001&HEIGHT=800&LAYERS=Borehole.records&STYLES=&FORMAT=image/png&DPI=120&MAP_RESOLUTION=120&FORMAT_OPTIONS=dpi:120&TRANSPARENT=TRUE)
Hi Sonomirco,
Thanks for your feedback, I’ve forwarded this feature request to the platform team!
Has there been any progress on this?
No there is no progress at the moment
Allthough it’s not possible to use WMS layers in the MapView or GeoJSONView, you create a leaflet map using folium and the WebView (this enables using WMS layers).
We have created a sample application here: https://demo.viktor.ai/public/wms-app
The source code of this app can be found here: https://github.com/viktor-platform/sample-WMS
