Output IDEA StatiCa - Depth of compression zone (position of neutral axis)
We would like to be able to retrieve the results of “Depth of compression zone” from IDEA StatiCa via the IDEA integration. At the moment, this is not included in the OutputXML. In the IDEA IOM documentation, this is mentioned and should be possible. Can this be added?
This would help us a lot also! Probably an issue for the IDEA Github. But still required!
We will need to check whether this data can already be retrieved through the IOM. @DHeijl could you share the section of the documentation you are referring to?
