Since recently it is possible to adjust the label of the red ‘update’ text, with update_label input. This is very useful. However the accompanying text (in black) can not be adjusted, and will not alway align which the text you devised for the button
I suggest to make (a part of) the accompanying text also adjustable.
Hi Guido, can you elaborate a bit on what is unclear about the current message? It seems to me that the text still correctly explains that the result shown in the view above are possibly out-of-date. In other words: what you write out if you could customize it?
Hi Matthijs,
I see your point. The wish comes from one of my key-users.
Here is his suggestion for this particular case anyway:
