Hello,
Is it possible to use OpenSeesPy library that modelling of the structural or geotechnical system help with coding in python. I am trying to modelling cross sections and structural system with the Python but I got this message when I tried to use OpenSeesPy library;
ModuleNotFoundError: No module named ‘openseespy’
I do not know maybe I did something wrong but If this library can work structural analysis can be performed with this pay.
Thanks.
Okay, I guess I solved the problem. I thought, when I applied the “viktor-cli install” command, system will be called the all packages directly but i did not work. I added the OpenSeesPy as openseespy==3.3.0.1.1 to requirements.txt manually then this problem is fixed.
Thanks.
Yes, you need to add the dependencies of your app in requirements.txt. For more information please read: Understand how your first app works | VIKTOR Documentation.
viktor-cli install
will install the dependencies listed in requirements.txt
