Not possible to determine the viktor-cli version
SDK: v12.7
Platform: v4.7
When the install comand is used this error message appears:
Could not determine the latest version of viktor-cli
Exiting because of an error: Could not get latest connector version
The same error appears when the comand version is used
Can you have a look at this thread to see if you can pin-point the problem?
Thanks, the problem is solved, there was error with the credentials
