When updating a project i get issues when:
- Changing project from private to internal
- Changing member to owner
Is this problem known?
Hi @Johan_Tuls ,
An internal project can only have an environment administrator as owner. So your sequence of events will result in this.
There should not be a possibility to have the option to change a member to owner in the event that this step was taken to make a project internal. Good for pointing this out.
Thanks for the response.
Related to the member - owner. Thanks that might be the case.
For the other bug is when i try to update a project from private to internal. This didn’t seem to work for some reason.
What is the response that you are getting for that case?
Hi @Johan_Tuls ,
We’ve just released an update that may solve this issue. Could you check for us?
