SDK: v12.2.0
Platform: v4.7.0
If the target sheet is called ‘sheet1’, the command cell_range produces a nonetype object, resulting in an error in render_spreadsheet
The template is filled correctly when the target sheet is called ‘Sheet1’, ‘1A.1’, …
