Hi. Wednesday my app was working fine, and then since yesterday i get the following message when trying to start
C:\Users\nbouwman\viktor-apps>viktor-cli.exe start --app-dir bovenleiding
File "<string>", line 1, in <module>
ModuleNotFoundError: No module named 'connector'
have tried reinstalling and then i get the following error:
C:\Users\nbouwman\viktor-apps>viktor-cli.exe install --app-dir bovenleiding
SDK version: 12.7.0 Connector version: 5.9.2
Creating app specific install dir viktor-docs
Creating app specific install dir viktor-stubs
Creating app specific install dir pip-cache
Creating app specific install dir signals
ERROR: Could not open requirements file: [Errno 21] Is a directory: '/usr/src/app/requirements.txt'
i havent changed really anything in the app.
Any suggestions?
Hi Natalie,
Could you confirm that the requirements.txt is indeed a file as it should be, located directly in the “bovenleiding” directory?
Also did you try to start a different app? Please do not reinstall if it doesn’t, to allow us to inspect the viktor-installs.
Hi Kevin,
the requirements.txt is definitely a txt file in the app folder
other apps give the same message. i tried 2 apps. one was still in the “old” folder system so it automatically moved/updated it (i.e. old cli method) but still gave the same message
Alright, could you navigate to the pip-cache folder and confirm that a file called connector.... exists? You should find it in:
C:\Users\nbouwman\.viktor\viktor-installs\<APP>-specific\pip-cache\
This looks as it should, so it feels like a docker issue. Can you try to restart your Docker Desktop?
That seems to have worked.
I restarted, had to put in a password for sharing files. but strange that just starting up in the morning didnt have the same effect.
I will be very pleased when you move away from Docker!
